the stock cooler was a joke, so loud and noisey. NZXT Kraken G10 and a corsair water cooling unit. It mad a difference temp wise was huge and...
Hi guys, Would love abit of input and advice on a new monitor, Im currently running a 23" IPS full HD which is nice but looking at a bigger...
Corsair Hydro Series H55 or Zalman LQ310
i have seen these but never really researched it much, i like the look of them very much my only gripe is that i currently have an antec kuhler...
Oops
had an issue with my dabs order and was mis-picked on my R9 290X i received an sapphire version instead of the MSI version i ordered but would...
ARE THE Corsair Vengeance K70 Backlit? and do any better than the 99.99?
thinking of adding a Prolimatech MK-26 Multi-VGA-Cooler and either 2x120mm or 2x140mm fans, does anybody no if it would fit into a corsair 500r case?
had the day off yesterday and mine got punished, was double XP on battlefield4 so I did a good 4hr session on it this thing gets loud and hot...
finally received my 290x other day and ran some tests what do you guys think? system as it stands: Platform: Windows 7 (build 7601, Service...
what would you do? i have had a 290x on order for a month still awaiting stock it was an early price + discount code i secured it at £388 all...
What do you guys make of this? http://www.tomshardware.com/reviews/r9-290-accelero-xtreme-290,3671.html I have a R9 290X on order should be...
thanks for the advice guys the new router is running nicely and improved not had any dropouts and improved speeds and signal well happy!
i like my corsair 1500 its great value and nice sound, the rotating cups can be alittle annoying at times, if i had the option to return and...
some of the comments here are making me question my pre-order of a 290x at £388 :/
how about this? http://www.maplin.co.uk/razer-kraken-expert-7.1-surround-sound-usb-gaming-headset-858193 anything razer is a winner!
save the extra and join your son imo. you dont get an awful lot extra i went the whole hog 10-12 months ago and bought razer tiamat 7.1 cost...
Thanks very tempting but my 500quid budget was for a 4k monitor but it wont be that price for years if ever! Great specs on that monitor and...
Hi guys, I'm currently running a 23" Dell IPS which i got two years ago which im pretty sure was recommended on here its a nice monitor and have...
