Try loosening the screws slightly on your CPU cooler, too much pressure around the socket area can cause memory detection issues since the memory...
The BIOS doesn't show CPU Core temperatures and that is what you are interested in seeing. Download RealTemp and run it within Windows both at...
Are you using the stock cooler or an after-market one? If after-market, Have you tried loosening off your CPU cooler mounting hardware slightly?...
