Only works if slot one is populated. Will try that, I updated from F8 so I'll give F7 and possibly F4 a go
I'll try the eraser trick mentioned in that thread but yeah, my RAM, mobo and CPU have been RMA'd twice
good to know, thanks. Anyone else have any ideas?
yeah, and since I have an OEM copy of win 7 I'd need to repurchase that as well :(
done, no improvement on the quantity I can use
I normaly have profile 1 enabled, this is it with it off
Mobo shows all RAM but only slot 1 is enabled
Disabled Auto 1333MHz Turbo Auto 1.5v 1.5v 6 Auto 4 Auto
I'll give that a shot now, the article (just the page I linked) says that this can happen with P55 boards, especialy with a i5 750 fitted. Since...
It shows the same as that picture, but in slot 3 "enabled slot" is blank and total memory reads 2048MB
Yes. Clean install. I belive the problem to be that the BIOS still has the 32 bit allocation table set up and that my 1gb graphics card and...
I have. Have you read my posts or the article I linked explaining the problem? I used 4gb of G.Skill DDR3 ripjaws from one of my friend's rigs...
The bios screen reads that there are 2gb sticks in both slots 1 & 3 (correct for the board) and that only the memory in slot 1 is "enabled"giving...
Noted. Everything else on the mobo is fine, just cannot see how I could remap the memory which seems to be the problem, nothing in the manual of...
No, not the RAM. RMA'd this twice (scan) first time round they replaced my CPU, thought it was a faulty memory controller, second time no fault...
Hello! I've been having some trouble with memory. Only 2GB of the 4 I have installed is "usable" Specs: Windows 7 Home Premium 64bit &...
