Thanks mate, that's a massive help.
Hi everyone, I've built myself a new computer, but find myself in need of some advice about RGB lighting. My motherboard is an Asus ROG Strix...
Thanks mate, that looks spot on!
Ok, I could do a custom shroud myself. Looks like I'll put in an RTX2060, the GTX1180 is the forerunner but $$$ dependant. I'd much rather trade...
Thanks for the advice mate, I'm sure I could squeeze that in at somepoint to try it out. I did have a sound card years ago that did make the sound...
Yeah? Fingers crossed then! But... knowing me it won't be soon, so I can always re-evaluate. But I'm skeptical, been waiting for AMD to catch up...
Toying with the idea of a new system this year, seeing as I keep on looking at it (and when I do that I normallyy end up with something ;)) so...
Wow, 5.1 on air, that's pretty good. Sure, I know it's old tech and I do have an upgrade list picked out but in the meantime just thought I'd...
Think I'll do a couple of benchmarks tomorrow to see how it goes. Did a couple tonight but only got one useable result after remembering to...
Good to know, thanks mate. I'm pretty happy with getting it to 4.2, I think that's been a fair improvement in my fps in game which is good. I...
It's an Asus A5M97 Evo R2 I've got. Not raised the voltages at all, in fact I lowered them slightly to 1.35 and 1.22 on the northbridge from what...
Ok, so after another run for 1hr 40mins CPU temps in HWiNFO was a max of 45.6°C and 63°C on the socket. Speed was a solid 4214Mhz across all 8...
Update: Prime 95 stress test was running for 2 hours or there abouts. AMD overdrive results showed a minimum thermal margin of 26.75°C (so...
Yeah buddy, still well below that. HWiNFO doesn't read the temps right on Vishera, possibly down to the temperature scale AMD uses to work out...
Cheers mate, I just couldn't figure out why, but didn't know if it was something preset in the motherboard or not. Seems fine at 1.2v though so...
Can anyone explain how a motherboard determines the default settings for a CPU in it's Bios? I was having a poke about recently and noticed my...
Thanks mate, that's fantastic. Saves me a lot of hassle and time!
Hi all, I recently upgraded my motherboard and CPU from an a10-6800k to an fx320. Just got it done tonight and I was going to reinstall windows...
Thanks mrbungle, I snagged a 2nd hand one off the of flea-bay under budget. Now all I need is a new case.
Thanks Vault-Tec, Me and my assumptions again, Doh! That changes things then, an overclock will be on the cards so I guess I'll have to pay a...
