Yeah that is the problem, it would cause more strain on the server so may not be feasible. Does anyone know if the 1.8 update will change the...
I've played on a server where they've done this before. There were different portals and you could go into a survival map, a creative map and an...
Could someone PM the I.P. please? I've sent PMs to all of the people listed in the OP, but no reply :(. I'd love to be able to play this game...
I imagine the resolution of the TV will be 1360 x 768, which is much smaller than the 1920 x 1080 resolution that a 24" monitor will have. So...
My GTX 570 gets hotter when both my monitors are connected. I believe this doesn't happen if your monitors are identical.
Thanks for the invite but seems like they're over capacity at the moment :waah:.
To be honest it would just be safer to go with the XMS3 stuff, the heat spreaders aren't necessary. I don't know how to put this but I'm kind of...
If you're just gaming and watching movies there won't be any difference between a 2500K and a 2600K. :thumb:
This is the program: link.
If you're just putting your OS on there you could get away with using a smaller drive. I have a 120GB SSD with Windows 7, all my programs and 3...
Are the multimedia keys on this in the right place or do they need to be vertical on the right? Link. If you can get past the location of...
I had to go through the same thing on my recent build, not a fun moment when you realise one of your hard drives is missing!
If you're on windows 7, press start and search for computer management. Open that up and then on the left click disk management.
If you open up computer management and the go to disk management does it show up there? If it does you just need to format it before it shows up!
Not much of a difference, obviously isn't the culprit!
I've just had a look inside and it appears it is already set up as you suggested. I think the sound is coming from either the CPU cooler or the...
I might install the fractal fan controller and just have the two fractals set at 50% at all times, as it's difficult to get to the back of my case...
Thanks for your help! So connect the front 2 fractal fans to 1 + 2, the bottom intake Be Quiet to 3 and the Gentle Typhoon to 4? Sorry if I've got...
I've had a play around with speedfan and I think I can also control the CPU fan. Which means that I can't control the Gentle Typhoon exhaust at...
I'm not really sure but I think I can control the 2 fractal fans at the front but not the other. They're all plugged in the same way so I can't...
