Hello, I have scoured the internet for a solution to this problem, you guys are my last hope! At work recently I was given another computer (so...
What I am actually after is not an unbranded laptop per se but a decent spec laptop that comes without an OS preinstalled. Is there such a thing?...
I am looking for a minimal Linux distro that I can install Flash on so basically an old laptop can be used as a web browser and view Youtube,...
I have a budget of ~£750. As you can see below I have gone slightly over that, which is fine. Any glaring errors I've made here? [IMG]
I have an ever-expanding movie collection that is becoming quite disorganised because I haven't been able to find any decent tag editing software....
I recently installed Win7 and it's OK, I'm a bit underwhelmed to be honest. It still feels flaky in a way that XP never did. And it uses three...
Hello all, I am thinking of spraying the inside of my case black but I'm not sure the best way to prep it and paint it. It's an Antec 300. Do...
Hi, I'm looking for some free software that I can use to capture screenshots in Windows. I'd like to be able to select an area anywhere on the...
Hi, I am using XP, have no plans to upgrade to Win7, but would like to run Media Center. I've tried downloading from MS but when I install it...
Hi there, I got hold of a couple of 120mm Sharkoon "Golf Ball" Silent E fans for case cooling. I have a 550W Be Quiet Dark Power PRO BN072 PSU....
Hello, I just got hold of a Inno3D GTX260 card and put it in to a Asus P5Q PRO Motherboard but XP is not recognising it at all - it doesn't even...
I need to finally upgrade my display (from a 17" CRT). I can't remember the exact video card I have but I think it's a GeForce 6800XT (it has VGA...
I have acquired a couple of old laptops (a Dell and a Thinkpad) with no OS installed and no driver disks. After installing XP most of the device...
Hello, I want to set up a home network. The idea is to have a server acting as a proxy server for internet access and also as a DHCP server to...
