Guessing it's not but just in case... If this is the P5Q Dlx in your sig then it should support AHCI as it's P45 / ICH10R. To change to AHCI - On...
Samsung ordered, thanks guys! :cooldude: WD Black was a bit much at £22 more than the F3, on a bit of a tight budget atm! And as said anything...
My old Raptor 76Gb is dying so I need a new OS drive, but can't afford an SSD or another Raptor atm. I need more space too as my 400Gb data drive...
I switched to Avast when AVG got bloated and annoying a while back. I tried Avira briefly but preferred Avast, but they both seem pretty good.
42 + 25... 67 seems too hot. I can't exactly remember the sort of temp that CPU would get to but I think under 60 would be the area to aim for,...
I've heard that can be caused by out of date AACS keys, if the version of PowerDVD bundled with the drive is old it may need updating. You should...
Sounds like it could be the memory to me too, definitely try running memtest
You can get that one a bit cheaper at Scan...
I'd try installing it on C: to make sure that's not the problem. You can change the tv download location to D: in the program and just have the...
You can turn off auto restart on BSODs so you can read the error message. The error should also show up in the Event Viewer. It could be...
I don't think it will work, it's not on the CPU support list and that motherboard only supports up to 1066 fsb cpus, the Q8200 is 1333.
Sounds like ram or the motherboard to me also, seen as you've tried two cards. Have you tried memtest? Are your CPU temps ok?
Have you tried uninstalling the webcam in add/remove programs, then reinstalling it? Could also try this from http://support.microsoft.com/kb/310575
What version of Windows are you using? Did the webcam need drivers before, if it did try downloading them from the manufacturers website.
Guessing you've tried the Toshiba support site already? There are some bios updates on there for some models of A200....
It should be fine without reinstalling.
Here's my attempt... :) [IMG] And one with better CPU and gfx... [IMG]
Don't have an answer for you, but here's another program you could try if you haven't already: http://www.cpuid.com/softwares/hwmonitor.html
I used http://3dpixel.net for a small site a while back, was very fast.
Some free ones, Spelunky Dwarf Fortress OpenTTD ZangbandTk or other roguealikes I've read the following will all work on the GMA950 in...
