I got myself a Radeon HD5450 for a spare setup, it was cheap and the low profile-ness might come in handy in a ITX case build I'm doing (very...
I have a 4 port router in my study supporting full-N wireless and WDS. I also have a PC in my garage (generally for music, radio, TV while I work...
I've just finished helping out a friend with a budget PC build. It's nothing more than a basic PC for web and email use and a bit of multimedia...
Just upgraded tonight from my old E2160 that I was running @ 3.3GHz daily to a Q9550, currently running at stock (for a while). Immediate...
I have a Linux server (Ubuntu) and I've set it up such that any of my other networked PCs can access it without a password. My 2 XP machines do...
I know lots of people are going to suggest that I don't use standby or that I reboot before gaming but I'm hoping for a more convenient solution....
I've currently got 2GB of OCZ Gold 1066MHz DDR3 memory in my ASUS P5E3 Deluxe motherboard. I want to upgrade to 4GB of ram and am not sure...
Hi I want some suggestions on how best to ventilate my SFF case. I need to put some vent holes through the window on the left side for my...
http://www.sitecom.com/product.php?productname=Wireless+300N+XR+Gigabit+Gaming+Router&productcode=WL-308+&productid=680 See link for details,...
This is probably a long shot but it'd be so useful. Is there any way that I can have my webspace seen in windows as a drive with a letter. (ie I...
I'm sure you're all going to tell me that this is fairly common knowledge but I had a revelation yesterday in my search for some replacement feet...
I've weighing up the options to replace my aging Linksys 11b router and I've noticed the ASUS on scan -...
HI I have a second rig that I use for gaming and other testing etc - no important data at all. It's running a 3x 80Gb RAID0 array on the ati...
Does it make sense that the achievable fsb on my motherboard is limited by the cpu that I have installed? I have an ASUS P5E3 deluxe...
I upgraded from XP to Vista a while back. My XP had MS Office 2003 which doesn't work properly with Vista (not saving Outlook passwords being the...
