I have been using 4GB of 800MHz DDR2 for a few years now and decided it was time to upgrade, so I bought 2x 4GB 1333MHz sticks (as mentioned...
[IMG] So yeah, I'm running Windows 7 Ultimate 64-bit, and for some reason the above happens when I set a different default audio (output, of...
Here is my problem: [IMG] As you can see, all my movies have different icons, even though they all open with VLC. I can't find out how to change...
I want to merge several videos into one longer video, but for some reason some of them have different languages as their default audio track. When...
Mine used to idle at around 36C but now it's gone up to 40-45C (it fluctuates a lot sometimes). I'm using a Scythe Ninja+ without the fan (it's...
I'm making a program which will help the user in making their own computer, and I've got a database made with tables for each type of component...
I'm trying to compress a 1.89GB .iso file so that it will fit on my "2GB" flash drive (which actually has a capacity of 1.86GB (2 000 060 416...
It's quite a short problem to explain: I can't get the program to run to debug. [IMG] I have no idea what the problem is (obviously) since...
I've been looking around for a version of Delphi (the programming language) which is compatible with Vista and I havn't been having much luck....
Only a short post, nothing to worry about. Can anyone tell me why DAEMON Tools wont work with my operating system? I'm running Vista Ultimate...
Firstly - yes I do have the vent server download, and yes I do have vent itself. I looked at a tutorial video on how to make a vent server, but...
I've got the SpeedLink Medusa 5.1 ProGamer headset, and the Creative X-Fi Xtreme Audio sound card. With XP Home 32-bit I had no problems with...
I was running SpeedFan on XP before I upgraded to Vista, and everything worked fine. It reported a temp value for my graphics card, CPU (both...
I went from XP Home 32-bit to Vista Ultimate 64-bit recently, and after fixing all but one of my problems, I am left with this: When I boot my PC,...
I think I'm just being really stupid, but I can't figure out how to install version 2.03 of the drivers... I got v2.02 with the keyboard, so...
