open your browser and type 192.168.1.1 in the url bar (connect to the router by lan). It will ask you for username and password(which you should...
I recommend Pinnacle or Windows movie maker for Windows processor. They are simple and easy. And recently i used Video Pad v4, since i wanted a...
there is software that i am using it for my iphone, CopyTrans Manager. I guess that would work on Ipods too !!
I would like HBO to create Game Of Thrones game, with open world rpg. That would be great !!
75 TB , i don't think somebody ever used all that space to keep data. In my opinion the number 75TB is just be used as a commercial rather than...
You don't need to buy a special cleaning tools for a screen. just a soft microfiber cloth and water will do. However i doubt using alcohol or...
Go for GENIUS mouses,they are cheap and with good quality. GENIUS Wireless NS-6015. is the one that i am using it, it doesn't have a fancy shape,...
Although Edge is much faster than chrome, However it has less features comparing to Chrome. For example signing in chrome, connects to your mails...
I think MSE is the best antivirus for low usage of CPU and Memory, However in my opinion I think Avast has a better security system than MSE with...
I totally agree with you, PES is less realistic than FIFA. The players in PES have that robotic movments,there is no real human physical sign in...
