Hello, First, before I overclock, I would like to know what temperatures are normal. My CPU is running at 49C when just browsing the internet....
Hello, I have an ASUS P4B and an Intel P4 1.8GHz. The temperatures are around 56C while I am playing Counter-strike source. Well first off if I...
Hello, I have a server that is wired to my router. Then I have several computers connected to my router by wireless. The server has a printer...
Hello, I have a server and I would like to server up my web page. I want a secure web server that is easy to set up and has php, mysql, etc....
Hello, I need to share my printer across my wireless network. Here is what I have: I have the Cable Modem hooked up to the Router. From the...
Hello, I set up a network on Windows XP and was wondering how secure they are. Being a programmer, nothing really is totally secure, it's just a...
Hello, Well I set up a server while back, which was XP, but I wanted Linux. I also rearranged the spot of the server and now am able to set up a...
Hello, I bought Half Life 2, and have Half Life 1 but I just really don't feel like playing it and I want to know what happens. I searched...
Hello, I need a motherboard temperature and voltage program. I have heard of MBM or whatever... Thanks, Alacritous
Mods, please delete. I solved the problem by doing nothing... no joke lol... anyway please delete. Alacritous
Hello, After getting my new computer all together and ready, I turned it on. It was kind of odd how slow it was when going through all the...
Hello, You know the cables that come from the PSU and have 1 molex, then a 2nd one feeds off from the 1st one, and then on some a third feeds off...
Hello, I'm sorry but, I have a really dumb question. The reason I ask this is because I just bought a ton of good stuff, :), and don't want to...
I have a server. I shut it down for a little while because I had to use some of the parts. I have everything together and started it up. The first...
Hello, Well I am formatting my hard drive, and I have some files on my Linux partition. For some reason, I can only get it to work on my 128mb...
Hello, This is pretty sad. OK well I thought the case I was buying had a power supply, but it doesn't. I need the cheapest power supply I can get...
Hello, What is the difference between a IC7-G and IC7-G MAXII ADVANCE? Alacritous
Hello, I'm not sure if this is in the right place, so just move it if its not. I was wondering if there were any good resources online or...
Hello, OK well I am making a new computer. I have a 2.6ghz processor which I will be overclocking to 3.0ghz. I also have 512mb DDR ram. I'm not...
Hello, I got a 2.6ghz processor, and not sure which motherboard to get. I would like to overclock it to a 3.0ghz, so keep that in mind. I have no...
