Is the 7750 any good, it looks like it kicks the bitch out of a 6670 and does not need extra power from the pSU? Itchy Rim
Hi, Can anyone please advise me what the most powerful Graphics card is that draws power only from the PCI-e slot and does not need extra power...
Sound like its bitched to me. Have a look on tomshardware site for the "Graphics Card Hierarchy" table, it lists the graphics cards according...
Why would anyone be using a discreet GPU for video rendering? Use the internal graphics from the i7 CPU, it is way better than using a discreet...
Shove that RAM in slots 2 and 4 and you need to RAM it home, its a tight fit to get it deep into the groove. Unless you really give it a good push...
If you wish to look at "Sandy" motherboards then the ASUS P8Z68 or MSI P8Z68 would be my starting point. In the ASUS range the P8Z68 V-Pro or...
Seconded, the 8 threads/4cores of the i7 will give better performance than the 4 threads/4cores of an i5. Is there any particular need to go...
If the video editing is a big part of the PC's use then I would think about going for a socket 2011 motherboard and CPU, specifically an i7 3930k....
Well, I got two spare as freebies, plus the brillo pad and solvent sachet they give you to remove it from the HSF/CPU if any toby fancies giving...
I bitched mine up to at least 82C to 83C for a few hours and it never bonded, mebbees I should have bitched it higher? Itchy Rim
Useless they are, I tried one on a CPU and it never bonded, my temperatures were 5C above normal and when I took the waterblock off the pad was...
FFS, just get her a 2nd hand PC from eBay for small money, no need to build a rig costing a load of money for her needs. Save the time of sourcing...
Adobe Premiere Pro CS5.5 is one of the best but it has a bit of a learning curve. Itchy Rim
That ubuntu Unity and 12.04 is a ****, its got more bugs than a prossies minge. I tried it but wiped it out and went back to 10.04LTS Itchy Rim
There is quite a big difference in price between the 3930k and the 3960x and the only spec difference I can see is 3.2GHz / 12mb L3 Cache for the...
Hi, Can any SATA cable be used for connecting a SATA III (6gbs) HDD to a motherboard or is there a specific cable type required with wiring...
Thx for the detailed reply, the video editing and encoding is not on a professional level, ie, it is not a source of income, rather, it is at a...
Hi, I am in the process of reconfiguring a couple of PC's, one of which will be used for video capture, encoding and streaming to the web, all...
George, Any news on the O rings for a Filco? Itchy Rim
Buy a second hand one from eBay and strip it down for parts, there are regular listings of P180's and if damaged it is generally the side panels...
