Not sure with one will is better, they will run with a opteron 165 and 1.5GB ram. Running the latest games. Also will running a ati card on a...
try cedega, http://www.transgaming.com/index.php?module=ContentExpress&func=display&ceid=2&meid=-1 works great.
if your on dapper you need to add extra repositories http://ubuntuguide.org/wiki/Dapper#How_to_add_extra_repositories then install codecs,...
heres what i do in order to get dual monitors, very smiple. get your driver installed, the open up xorg.conf and add to section "Device"...
first make sure you have the ati driver installed and setup correctly. Making sure you change the driver part in the xorg.conf to fglrx. Then run...
bit off topic but can the xbox 360 universal remote work with windows xp mce.
