Hi again. Thanks for all the help cpemma. It turns out that either the transistors i was using weren't compatible with bc109s or i had wired them...
yeah seen that version. I didnt like the fact that you are using a couple of wires to create a capacitance. Doesnt seem like a precise science...
Dont suppose you could suggest an alternative method of testing then? Thanks for all that info. It's cleared a few things up in my head :)...
first thing is... Why wouldnt my method work as I am already receiving the signal so surely amplifying it and cleaning it up will sort it or will...
Hiya, I'm in the process of build an MSF (60KHz atomic clock time signal) receiver for my a-level electronics coursework and wondering what is...
does anybody have any information on how to use crystals? I just cant find any info on how to set them up to work in a clock circuit. Or any...
I'm surprised that no-one has pointed out / noticed that when neo is leaving his meeting with the architect the architect says that he wont see...
Wow gentoo is really amazing if you compile your system from stage 1. On RH8 which I was previousl0y running OOo took about a minute to load any...
I've had mixed experiences with hotplugging hard drives. I've been succesful and then one time it shut down my PC and I thought i'd killed it :(...
I'm guessing a master fans on/off switch and a speed control as it looks like a rheostat to me...
Jus looking at this I thought wouldn't it be great if you didn't have any letters on your keys. Looks stylish and prevents little kids who can't...
The linux source code is available but not in the form which you might expect. The kernel code is absolutely free and can be found at:...
Tips for a linux newbie: 1. Get used to the command line. You will NOT be a linux god without command line knowledge 2. understand how to...
First off make sure that your NIC is working because I had lots of problems with mine. Then to enable dhcp the GUI setup for your NIC in X will be...
are you sure that you are compiling the right modules into your kernel? It wont be the compiler gcc is the standard linux compiler and I'm sure...
Well I dont know what guide you followed exactly but it looks like you haven't recompiled properly or have missed out some vital modules for your...
I wouldn't recommend installing the webserver via RPM's as they give you no control into the configuration although they are easy. If you do...
not in amsn there isn't.
yeah I've been wanting to do that for a while still haven't done it *tut* *makes note to look at LFS again* and btw I do NOT use a mac :grr:...
I guess I just wasnt concentrating last time I tried. It works now thanks :) Also you do not need the terminal option checked. Mine just runs the...
