ok guys, im looking for a matx mobo. here are the following components i want to run: AMD Phenom 9850 Black Edition AM2+ Quad Core 125W Asus...
anyone?
hmmm what about this one: SONY VAIO FW Series http://www.newegg.com/Product/Product.aspx?Item=N82E16834117793 Intel Core 2 Duo P8400 2.26G...
hello, i need a laptop for under 1000$ USD. i will be using it mostly for music, browsing, school work, recording (i have a DI for my...
bump? fyi: no info with the mic trick im getting it off and on while running super pi... i get the fealing im being ignored....
hey, everybody. its the motherboard! edit: so ive decided to combind my two rigs into one awesome portable kickass one. ok two questions....
it is...
a WD 120GB hdd...dont ask it just riped it self apart like a firestone tire...
tech advice...dont take my bad luck with you... :hehe:
new idea ok i have a new idea, why dont i just put the other nivida card i have in the pc? and see if it makes noise. that will tell us if its...
i will test it out after i finish some paper work... just a side thought if it where the mother board thats causing crappy performance in games...
mobo? so i pluged in a neopower 480 and i get the same damn thing....im starting to think my mother board is a pice of ****, or evga is a ******...
how much is £450 in usd??? btw im not giving up yet...ima find you something
is there any way i can post the log file? i am just noticling i am hearing the electronic whining while eriting this messagne a little bit...
as a mac user i am inclined to say a apple laptop...
what ever happened to "load your code up in Xcode, check PowerPC, check Intel, hit compile." i didnt think it was that hard... anyways, have...
good idea.....ill do it tonight before i unwire my psu should i post mobo specs? links? aswell
yes well i think where overlooking the fact that i get like 10fps in games. also i didnt have much luck with the microphone thing. tommarow if i...
ummm not to be a noob but what are MOSFETs and chokes?
ill be sure to print that out and try it out as soon as i get home, thanks for the feedback. ill be sure to let you know what happens
