Thanks for all the positive feedback. At the moment I'm visiting my folks so there's not alot of modding going on, but I'm planning to borrow a...
- December 22 update - [link] Probably not worth the month long wait, but here's another update.
Believe it or not, but here's an update to my project log. It's been a month since my last update, while I haven't had the chance to do any major...
Thanks guys! Deathrow, try http://www.repsol.dk they got up to 1" thick acrylic. .johan
- October 31 update - [link] A new top for the Maze 3 and more hose separators.
Time for another small update. Modding has been slow for the past few days and these photos are actually from last week which I haven't had the...
I don't think you'll need 2GB for the server. That's for the client which has to deal with large amount of textures which the server doesn't have...
Thanks for all the positive comments, there will be some modding done today so hopefully another update tonight. I bought some additional water...
Thanks for the help. I just realized there's a separate forum for cooling, so any mods reading this, please move this thread. .johan
Yeah the TDX is pretty neat. The thing is I got both the maze4 and RBX blocks already so unless I'd want to own the whole DD series of CPU blocks...
Easy really, which block is the best performer, the Maze4 or the RBX? I got both blocks but need to decide which to use for my mod (see sig)....
I'd get cheaper tools to start with, especially if you only have $500 to spend. Then when you have some experience get better quality tools for...
I agree with Tulatin, use a guide for the jig saw. I use a 1x1" aluminum L-profile as a guide when i need really straight cuts. I also recommend...
Thanks frodo! I love all the shiny parts, takes a lot of time but looks so much nicer imo.
- October 23 update - [link] Just a small update with the acrylic hose holders.
As promised here's the acrylic hose holder. It was 90% made by a friend (Tommy.N on BT), all I did was to polish it up and take some pictures....
- October 22 update - [link - link] Two updates today.
So this is the post today that's actually about today. As I've said before the front of the case will be covered with Akasa mat but since...
Hi again, it's been a while since my last post as I've had very little time for modding. This post should have been posted yesterday and there is...
Thanks for all the feedback. After posting I started to lean even more towards the mat, not because of the sanding being a great PITA but because...
