Hey, I just bought a new WD Green 4TB a few days ago (WD40EZRX), and the Spin-Up Time reading in S.M.A.R.T has me concerned. The Worst value is...
Hey, what does everyone use to clean the outside of there rigs? I'm trying to get the finger prints off of the glossy black paint on the top of my...
Hey everyone, I'm planning to upgrade to the Gigabyte GA-Z87X-D3H. http://www.gigabyte.com.au/products/product-page.aspx?pid=4518#sp The thing...
Hey, my system will not load Windows XP Pro, what happens is most of the time the system will POST, then the Windows XP loading screen will show...
My Monitor will flick for about half a second sometimes, but only with my ATi 5770. I have 2 monitors set to the same res in extended mode. I...
Hey, is there any Freeware software that can remove the DRM from .m4a files that works on Windows 7 x64? Thanks :) EDIT: I've converted my files...
Hey, has anyone noticed that Duke Nukem Forever takes forever to load? This happend on my system and all I did was delete the AMD Dual Core...
Hey, I was looking to get a UPS for my Rig, (Specs are in my signature) I was thinking of getting the APC BACK-UPS CS 650VA 400Watts. I know my...
How long do you guys keep your Hard Drives for before replacing them with a new one? I was thinking 4-5 years would be a good time to replace one,...
For anyone who may own a BenQ GL2230 Monitor, is the screen Matte or Glossy? I've already tried looking at the official site, google, searching...
I have found that Windows is disabling the write caching on my internal WD500GB when my WD1.5TB E-SATA external drive is connected, making file...
I can't find what the difference is between a Access Point Client and a Wireless Repeater? I know a Wireless repeater connects wirelessly to...
I'm planning to buy a WD15EARS for backups. My current setup is Win7 on my WD1500HLFS (150GB raptor), and WinXP and my data is on my WD5000AADS...
Hey, I have a NZXT Classic Series Alpha case and the fan on the side (Xigmatek CLF-F1251 120mm Blue) is making a bit of a high pitch noise, I...
Hey, can anyone get ATi Theater Mode to work in Windows 7? This has always worked for me in XP. I am in Extended Desktop Mode and Theater Mode is...
Hey, my system is about a year old now (specs are in my sig) and until the last couple of weeks, my system has been randomly getting Blue Screens...
Hey, does anyone know how to calculate the optimal speed of RAM with the Core i series of CPUs? For example, if I had a Core i7-880, which has a...
Hey, did anyone know of any good freeware JPG recovery software? I have a .jpg file and when I try to open it Windows just opens up the picture...
I am going to format my Windows 7 RC1 install which is on the same Hard drive as my Windows XP Pro SP3 install (But different partitions). XP is...
