How are finding it so far?
Just a suggestion - maybe its best to keep DVD watching separate? I was already thinking about getting a 2ry drive to allow for direct copying and...
Oh no worries Shamrock I probably wasn't clear enough about what I meant. So if you see my point now do you agree that its probably the best bet...
I'm building a rig similar to yours so I can back the E6750 as a great choice. Don't know how much you're finding that RAM for but I've seen...
Some hacks up already? That was quick!
Congrats, sounds like everything's working nicely. Hope mine goes as well as yours did.
I understand what you're saying but.... ....in kenco's experience its the most quiet of the big brands that he/she has experienced. That's why...
Hmm so what's the moral here? All good DVD drives are fairly loud, but the NEC is both quieter and more reliable than most? That seems like a...
What's the quietest drive out there? Quiet while reasonable at read/writing too though....
I have a certain price point in mind although this is a rough guide. The importance for me is value for money. I want a good quality rig that will...
Well I'm in the UK. The Sony NEC Optiarc linked previously is the one most recommended in the reviews I see. I know you need compatible discs for...
Hi After some a long while of advice and research, I've come up with a spec list for my 1st PC build. Just for background its a PC I'll take to...
I don't understand, what do you mean?
Can anyone recommend me a SATA DVD drive. Must have features: DVD writer, supports DVD+/-R, black faceplate, fast, quiet Nice additional...
I can't see why your RAM is costing you £100+ Your last spec list you've listed this2x1Gb Geil but that costs £56.39 from overclockers. Why...
This looks really interesting. I'm a maths student and used to do computing. Problem is I only ever learnt BASIC (and QBASIC at that) which I...
What are you looking to run within the virtualisation?
I would recommend Gigabyte GA-P35-DS3R if you have RAID interests (or will in the future). In my opinion I don't think the P35C version is...
I would say go for the MX1000. I've had mine for a couple years and its perfect. Fits well in the hand and has really useful well-placed buttons...
Its your first build so you're a little apprehensive but don't worry about it. Just keep everything simple. Touch the case after plugging in...
