Thanks to Throbbi and xaser04 For the helpful information it all helped to sort stuff out in my head:worried: There was no budging on the case...
Hi Jipa Thanks vm for your input. The graphic card will be a little tight but will go. A little confused at the price though ,the 5850 seems to...
Hi Hoping for some advice here. After reading the excellent article "Build a £410 future proof PC" in this months CPC mag. got me thinking of...
Have found the H50 to work very well and silently in a set up similar to yours. Attached the radiator to the top outlet fan in a push pull set...
The FT02 is showing on Scan in surprisingly their large case section with a price to match.Only pre-order at the moment.It is pretty deep at...
Maybe [Seasonic x 750] will tick all your boxes It has excellent reviews, gold certificate and due to it's high efficiency produces very low heat...
