Thanks for the replies. I certainly appreciate it because I can come up with a better decision.
Which one should I get and why is one better than the other? Which one costs less?
Thanks for replying. Appreciate it. :rock: PS: I've got one more question, What do you suggest I should buy next For example, what are really...
K, I fixed the links
Which one do you think is better? CASE 1 or CASE 2 Plus, would this power supply look good with the case(s)? POWER SUPPLY Also, what...
I put it all on ignore and still nothing. I think Nexxo is right, but all is well. I'll probably buy that and try to sell the PC later on. What I...
Still nothing and voltages arel 0.
This started showing up when I installed my first windows for this computer back in 2003, whic was Windows 2000 Server version. Every time I start...
