You are not running the firewall are you? Cause looking at what you have done should work, I had the same problem when setting up a wireless...
The latest version of ZA is great too, well worth the money to buy the full product to get all features. Has under pop, and over popup...
Yep both the routers that the above posters mentioned are good a location to get these is Ebuyer Great site as it has user comments/rating system...
Microsofts term for the automatic ip addressing is called APIPA There is a way you can disable that but involves adding a DWORD in the...
