hello wireframe you wouldn't happen to have a reload cd would you
i have two copy's of which i downloaded 1 is an oem version the other isn't, which one do i use.
the reload cd's i got i have got from others, i got the notebook second hand. ok thankyou for the advice and infomation much obliged kevin
i have got the blue version 0.4 reload backup cd and a version 9.0.0 or simialar, the 0.4 is incompatible and the other reloads but when notebook...
this partition on my hard drive that holds the original copy of xp home that im trying to reload is ther another way to get this unlocked without...
thankyou for the info. so if someone had the same notebook and they had ther reload cd would it not work on mine? thanks kev
hello to all. i have a notebook model and make Tiny A535 im in need to find what version of the reload cd is the right one for my machine,...
hello i have a notebook made by Tiny model A535 im in need to find out what version of reload cd i need for this machine( i am running xp home),...
