Well eventually got to the bottom of the noise: What a faf - Turns out the noise is coming from my PSU (guess what - going to RMA that)...
Thanks for the reply I think that adapter plate comes with the waterblock. However, it will mean draining the system in order to change the...
Hello All You have all been very helpfull in the past - so I hope you can help again: Looks like my current 8800 GT graphics card is on its...
RMA'ing the board - just don't like the idea that there could be something wrong. The noise is now happening with 6GB (3 Sticks) of ram so...
So it could actually be a motherboard problem? This was a new build so the Mobo is brand new
Mouse - very funny :-) When the 6Gb of ram are used individually there is not a sound. It is only when all 6 slots are filled that you get a...
Noisy Ram Has this happened to anyone before or is it something I am doing wrong. 2 things - 1. I have an ASUS P6TD Deluxe board and...
Just reading another thread on LLC - I have managed to get it everthing stable under Prime95 at 3.8 and by having LLC disabled the temps are a bit...
So what you are saying basically is - if your system is stable with LLC off then you can keep it off there is no need to have it turned on?...
Hello All Just wondering what speed I should be runnig my Swiftech pump? It is the variable one so I can choose to have it running very slow,...
Hello Yes running Windows 7. Did not have any problems with Prime95 starting (obviously got the 64bit version) Ran on the default Bios...
Well bit of an update Took out 3 sticks of the RAM so I was only running 6GB - put everthing in the bios back to defaults and restarted....
Surely the voltage must be enough - 1.36v is enough to overclock it to 4gh - this is only running at stock 2.6GHz The machine does not crash at...
Yup as soon as you start prime 95 all the cores start working, then they all stop one buy one almost instantly - Fail with an error in Prime95...
OK, hope all you people out there can help - cos this is driving me nuts. Just built a new system: Asus P6TD delux mobo Core i7 920 12 GB...
