Well I have a USB to ps/2 adapter but im not sure if they are reversable...i mean it would make sense...but are they? If i use an adapter then I...
im working on button that would be under the keyboard that could disable it so noone could use my computer, and I was wondering which of the 7 or...
when I did my first window I used some CDs to keep it looking like a rectangle, so it kinda looked like this in the end: ______ )_____( It...
its a work in progress. where should it go?
no, its too cramped in there to do that. The bottom of the drive is sitting on the bottom layer of plastic on the very bottom cube. Its a really...
i posted it here, then I saw the project log forum and since it is a work in progress, I put it there. I would remove this one if i knew how...
ya the pen drive came w/ a cord so i use that. The colors are red yellow white green blue orange red so I suppose I could wire one up to each side...
an egg eh? ill have to try that some time. sounds fun. did you do over easy or scrambled?
[IMG] [IMG] [IMG] Thats right! a USB Rubiks Memory Cube! The pen drive I had fit perfectally inside the cube, and although it will...
Or am I a genius?? [IMG] [IMG] [IMG] Thats right! a USB Rubiks Memory Cube! The pen drive I had fit perfectally inside the cube, and...
when i cut it with a dremel it stinks really badly. When i use a hacksaw it cracks the edges. When I go over a line 1000 times with a box cutter...
Whats the best way to cut acrylic? I have tried a dremels and hacksaws and jigsaws and box cutters, but it never comes out right.
ok...well i feel really stupid now. the paint was dry! I had just put too much on in a couple of spots so it still looked shiny. It was also...
it was perfectally clean (i had just dried it after wet sanding) and I had shaken the can plenty, but it might have been that I was at the very...
I put the last coat of spraypaint on a case 2 days ago and the paint is still wet! I just dont know!
I somehow ended up with a light rope a foot and a half long that is really bright and would be perfect in a case, but there is no switch. It plugs...
I would do that only the drive is no longer a CD rom drive. The whole point of the mod was to turn a CD rom drive into a cup holder or somthing...
Im working on making an external button for a CD rom drive, and I found the 2 points that I need to connect wires to inside the drive but they are...
iron eh? Well, at least it makes a good picture frame now...
Ok, so im working on an extrnal CD opening button, and I found which points to solder the wires to, and I have the button I am going to connect,...
