hey anime you still there?
can i still purchase the LED's? I live in southern california and how long will it take to get here?
well, don't know if this might help but when i had the original fans in my PC7, the intakes weren't nearly as loud as my thermaltakes now
well, so far i only managed to barely break 7000 in 3Dmark2001...
thanks...but a bit disappointed in the computer...maybe I just haven't pushed its limits yet.:D
what heatsink/fan combo are you running and what temp. are you getting. I have thermaltake dragon and am running at 46 celsius idle and up to 53
i know this isn't really the best way but i drilled a hole, used a nibbler and sanded the circle smooth, doesn't matter much my fan grill covered...
alright, so I put them on different channels but don't seem to notice the speed degradation, especially while I was installing MOH from the...
after swapping the mobo with one from Fry's, it finally worked, but I still put an order out for an Alpha cooler. one more question, if i...
what about the motherboard sensor, could that be wrong?
wow, i took a look at the price of one of those...$59 at heatsink factory
ok, ram doesn't seem to be the problem, i tool each of them out individually and it performed the same. i'm a bit glad i'm getting rid of this...
yeah i did, exactly what i used arctic silver3. i checked the heatsink and it seems alright. So basically at this point, can i rule out defective...
ok so before i go run off to go buy another cpu fan, i'm going to check that my cpu heatsink is seated properly.
is the CPU temp of 48~52 celsius too high? What about the system temperature? do you think its the heatsinks fault?
Feeling a bit ambitious, I decided to build my own computer. now i've run into a problem, after bootup with cdrom, it hangs during the beginning...
