where might I go about putting a PSOne monitor onto my Chieftec case? I have a midtower dragon and I was thinkin the door... but... that's a...
thanks, I'll try that... tho it would be nice to get all 64 lights working... o well, I'll try to figure it out I guess
I know I could mount it just fine, but I always have trouble with figuring out wiring, and I don't know which type of port it should be wired to...
I need a lil help with something.... so, a couple of years ago I got a Bitman. They're these japanese things that have a 8x8 LED matrix screen....
AMD Athlon XP 2700+, 2.16ghz, Asus A7N8X Deluxe, GeForce FX 5700 Ultra, 1.5GB DDR Ram, 120 GB Seagate, Enermax 2x2 Ultimate Fan Controller, Sony...
wow, awesome... we almost have the same computer setup too!! freakish...
OK... so I started the mod... NOT EASY. many wires that are rare need to be extended, and the DVD drive from the PS2 doesn't want to come out....
it's very useful for me: makes it easier for me to use my VGA box, which I will integrate into the system so that all I have to do is change...
.....now i'm intrigued.
wait wait... it's been done!? CRAP... well.. I'ma do it anyway... and yes, I have quite the computer to go with the PS2, and a very nice case that...
PS2... inside my PC. I have all the measurements, and have shifted things around in my PC so that it should fit just fine. it will require:...
