yer sounds good would probaly be easier to buy an acrilic case n then make side pannels or paint the ones on it with a alu paint
pics of what your going to use would be good
That looks like one of my cases exept the matrix theme. Vice nice job looks excellent
Anyone ever thought of making a half acrylic half aluminium case. So basically 1 side is all transparent and 1 side isnt, i think it would look...
I would of thought youd just do same to both m8
ok i will give it a try thanks
about 24 hours or so
Hycote double acrylic grey And am i right to belive i carnt use the lacquer i bought?
ive done another plastic front n all i did was wipe it down n give it 2 coats of primer and 2 coats of gloss but it looks like **** what should i...
Is that for the inside of the case or outside or either?
Ive bought.... Hycote Double Acrylic Concentrated Paint Grey Primer Gloss Black Clear Lacquer
i mean now ive sanded the top of the case down to the bare metal will i have to sand the sides down the same or can i just take the first layer of...
will i have to take all the case down to the bare metal because it will be diffrent shades? Also, Can i use the same paint technique on the...
Ive already had a go at the top of the case and its down to bare metal that a bad thing?
Thanks very much you people are so helpfull lol Is it ok to use a sander with the right grit paper aslong as u keep it in one direction then...
Thanks very much that seems to be what i was looking for, What about sanding the plasic front of the case?
No i dont have an air compressor, ive got various sanders tho
Hi, im new to the whole modding scene and before I start to chop my case up and put windows in I would like to give it a lick of paint. Ive read a...
