Installed XBMCbuntu and been playing with it all weekend, but too many problems so tomorrow I'm installing windows.
I'm sure a rad could be squeezed in but it would be very tight. I'm going to use this computer as an htpc in my bedroom and mostly stream movies...
Got an old cubit 3 computer from 2004 I decided to upgrade. Most of the hardware will be replaced and the case will get a quick makeover. The...
Moved the radiator I don't have a graphics card yet but I noticed that with my big radiator there might not be enough space for it. So I moved...
Thanks, but I wouldn't call the case small. Many mATX cases are smaller and this is a mITX case, but I love how easy it is to mod.
Fillport and hole for cables Added a fillport and made a bigger hole for the PSU cables. The black rubber around the hole is only to protect...
HAL 9010 - A water cooled Bitfenix prodigy case with a HAL 9000 inspired theme. The title says it all so lets get started. Component For...
It's a standard ATX and I measured the voltage with and old motherboard connected and running. So I would guess a 50-100W load. I run both with...
I have modded a PSU to make it (semi) passive. It works but I have a too high voltage on the 3.3V and it's too low on 5V and 12V. I can increase...
