Hey everyone, just got a new x850pro and flashed the bios to X850XTPE. The card is working great, all 16 pipes unlocked and running stable and...
Yeah I think I'm kaibashed as they say. I'll be buying a router ASAP. I didn't think this would be easy with an old linksys 4 port hub. Anyway,...
I work at the ISP in question. We actually block it out somehow or another...I'll try it though
So if my systems aren't in the same ip range, there's no way I can file share? Is there a way I can make the subnet masks the same without setting...
Firewalls are disabled, workgroup names are the same, not to mention I cannot set up staticly because my isp does not allow it. Should I change...
They can both get onto the internet fine. All I want to do is filesharing.
What do you mean by ips in the "correct range" what is the correct range? They're both seeing the same dhcp server, dns servers, and have...
ST8: When I do what you suggested (eg. //**** I can only get to the local machine I'm on, it doesn't work for the other machine. [when I'm on pc...
oh yeah, I'm running through dhcp on both systems as my isp does not allow me to connect staticly
sorry for the lack of info mates...I'm on a standard cable internet connection (10mbit/1mbit) and I have all drives on both systems set up for...
I'll try that when I get home in a half hour (at work). I don't think that would work though
Hey guys, first time posting, and I'm ready to throw my copy of XP out the window. Anyway, I've got a Linksys 4 port hub and two pc's (both...
