Just thought I'd post to say I got my free mask today!! It's been almost a month but they did send it no questions asked. I should also...
Thought I'd share.... Broke out the dremel to cut my first 120mm hole (first time cutting metal with it). It was a snap. I used a reinforced...
posting an answer to my own question here but FYI. Virtual hideout http://www.virtual-hideout.net/guides/dremel/index.shtml has a nice guide to...
I beleive this is my first post to the bit-tech forum! I've been a browser for a while now since I started modding my Noblesse case...and have...
Looks cool. Just a suggestion...you may want to use a more porous material for the X. If you're concerned at all, using styrofoam or plastic...
Linkitch. That'd be cool. I have a MS IntelliMouse Explorer and would like to change the LED. Problem is there's no screw holding the casing...
