I the low profile and the side in side out. I am going to build a project which involves cooling a epia nehemiah mobo. The low profile helps me...
I want to find this block any one seen it?
Here's one graph http://members.cox.net/semicycle/pump/pump-hvw.jpg here's another http://members.cox.net/semicycle/pump/pump-gvw.jpg
I found some graphs comparing this pump to some others, and it out performed the eheim 1046 and the hydor L20 and its only $16. What do you guys...
Is there any coolant out there that is clear, or are they all colored?
I know I could passively cool it, but I want to water cool it. What kind of epoxy is recommended for affixing a block. I don't really car how the...
http://www.mini-itx.com/reviews/nehemiah/#s01 It looks like the existing heat sink is epoxied on. :eyebrow:
Another question, how would I adapt a block to fit that board, any ideas?
I'm trying to build a very small computer case and have watercooling as part of its design. My question is are there any small water cooling pumps...
In the roofing section at home depot there is a material called peel n seal (I think that's right) that and 8# carpet padding are used to do home...
