The drive bay reservoir that I'm using has the pump sitting underneath the water tank, yes. I have the one that's designed for a single pump, but...
Thanks! :) Yes, I'm very happy with the Obsidian - apart from the trouble with the reservoir I have only good things to say about the case so far.
Hello again! I know I'm resurrecting a rather old thread here, but I thought I might as well show those of you who might be interested how this...
Thank you very much for your help, H2O! Things are starting to fall into place now, I think - even though it seems that I'll wind up going a tad...
Okay, I've pretty much decided to go with H2O's advice and use the SilverStone TJ07B-W case and a 480 radiator (maybe the ThermoChill PA120.4)....
Thanks! :D I like to do as much research as possible before jumping into something that's new to me.
Thank you, everybody, for your thoughts and suggestions so far! :thumb: They are really appreciated! As for the necessity (or, rather, the lack...
I'm quite flexible on just about any part of this setup. :D Thank you for your suggestions, I'll definitely look into them!
VadimWolf, the more I think about your suggestion, the more I'm starting to think that I might actually need more radiators if I want some room...
Do you really think it will be that bad? I tried to do some calculations on this. The i7 920 has a TDP of 130 W. The TDP for a single HD 4890 is...
Hello! I'm considering building a new PC at the moment, and in that regard I'm strongly considering jumping onto the water cooling bandwagon....
