I would like some advises regarding the new computer I'm planning to built. First of all, I live in Canada and I will be getting all the pieces...
I live in Montreal. Those sites are good but some prices are better at Soho and NCIX. It is still kinda hard to have a better PC for my...
Is there any way to get the newegg products deliver in Canada? Since the canadian dollar worth more that the USD it would be great for me...
@pillow Since I live in Canada newegg wouldn't be the best site to shop. I decided to try to make my own config on ncix.com and see how mutch...
If i try to build it with the peaces from http://www.sohodiffusion.com, which is the closest dealer and seam to have fairly low prices, it's...
Buiding my own PC would be more expensive and I would have to buy Windows Vista ($$$). Do you thin a 128MB NVIDIA GeForce 8300GS would be able to...
I want to buy a pre-made computer since I have no knowledge in computer assembly. I've been browsing arround for few days and Dell seam to have...
Hi, For the same price i can have: - AMD Athlon™ 64 X2 5000+ - 22" widescreen ----------------- or ----------------- - Intel® Core™2 Duo E4500...
200 views and only 2 answer... Come on guys I need your help!! Thanks
Thanks for your reply. I also think it would fit but I'd like to hear other people opinons. Is there anybody who have this case? Thanks!
For Video Card: ATI Radeon X1600 Pro Is there any way to find a case of this size: 15,5cm x 12cm x 8.5cm? Otherwise, can i mod an existing 500W...
Greetings! I have a question about the CoolerMaster Cavalier 4 case. Specs of the system: MB: Abit AW9D CPU: Core 2 duo e6400 2.13Ghz...
