Indeed it's a 80mm fan will by me a 120mm after moving into new home. Thanks for commenting
Hi all This is the final for the paint job on my case mod. Hope you all appriciate my paint job. [IMG] Front clear coated [IMG] Front...
Hi all I've installed the plexi on the skull side and glued on the eye. I also primed the front case. Here are a few shots. [IMG] [IMG]...
I've completed the wet sanding of the top and skull side here are some cliché of my work. When applying the compound I was becoming more and...
Got some work done on the paint job and the front lcd. I've sanded the second paint coat with 600 grit. Applied the cleat coat here the...
I made this plexi and painted black on the back but I will do another but fully black since this one was for the 4x20 lcd. The plex is riveted on...
The mesh will be cutted out. I'm still planning this out as to putting my current 4x20 LCD or this 5" LCD screen for a xbox [IMG] I have not...
First coat of paint dried and hardened time to wet sand 600 grit. And after a few hours of sanding here are my results of the second coat of...
Hi. Did some work on the front panel yesterday and here are the results [IMG] Front mesh will replace the 2 40mm fan duct and LCD. The...
Here is how I started my skull cut-out. Printed out the skull on 4 sheets of paper with the poster option of the printer. Taped the 4 sheets...
Today I've primed the 2 side panels and the top and applied the first coat of paint. [IMG] [IMG] Skull side primed [IMG] Top primed...
Updated march 15 Here's some off my work done on the front case. I cutted out the SKULL text made off bones letters [IMG] I also made...
I will take your suggestion in consideration thanks
Painted MB tray and psu. I primed and painted. Here are some pics. [IMG] [IMG] [IMG] My nest step will be painting the out side case.
Thanks.. I just finished painting the MB tray and the power supply will post pics tomorrow.
Finished painting the interior of the case and here is the results, and i'm pretty happy and it was a practice with aerosol paint [IMG]...
Got up early this morning and did little things to my mod. Here I cutted out the two rear blowholes [IMG] And the dismentled the hole case....
I have used these cut-off wheels [IMG]
Thanx for your comments Just completes my fan duct here are my results First started with mesurement [IMG] And after some dremel and...
Project log discussion here Thank you
