oh whys my name got whats a dremel? under it.... cant i have something better mr admin :-)
ill try the drivers again becouse what you are saying there is basicly exactly what is going on...
seen 6600gt for about £80 wich i think is cheap or i can get the same card for next to nothing... but i do think it requires a new card
ok ive had a look at its allready set to what it should be so no good on that one... as for the codecs ive installed new ones then formatid so...
Thanks for the reply ill check if that works once i get back from work
ive got a very annoying problem.. Specs: win xp sp2 fx550 gfx 512ddr 2.5 amd ok heres the prob, when i play dvd's or any other...
