Cash Yep, only enough for a cpu and I figure it will most likely be the last performance based upgrade I make to this system before replacing the...
I recently won a bit of cash in the lotto and so I am looking to upgrade my processor. I currently have the following in my system: Athlon 64...
All Done!! Well the new card is installed and I have my primary monitor running off of it. The secondary monitor is run off the old card and the...
That's the one I bought. Installing in the next hour or so...
Either the x1650 Pro 512 MB PCI-E or x1950 Pro 256 MB PCI-E depending on how much extra I want to spend (have a gift card for part of it).
OK, thanks everyone. Didn't want to go through the hassle of having to return a card if I couldn't use it. Going to buy the card today.
So even with two cards you can't have three visual output devices working? Can anyone else confirm this? Would I just be better off keeping the...
That's the plan but as far as I understood it with two monitors already hooked up to the current video card if I added an S-Video connection it...
I am hoping to install a second video card in order to hook up a TV to my system. I currently have two monitors hooked up to a Radeon x800 on a...
