You ruined it Highland3r. I was really looking forward to buying a new ram stick :hehe: Well this was fun. So what's your opinion, i should...
Doh! Doh! I'm under the unpleasent impression i killed my ram. @195 memtest ran fine, so i decided to up to 200. there it ran fine for an...
6 hours of memtest, not a single error. I think the ram is stable, which explains why i got errors when the multiplier was 12.5. either way, any...
Or so i wish... Anyhow, prime seemed to fail again this time with a "FATAL ERROR - rounding paka paka". Not sure what this can be - this is @ 185...
x12 Edit: ok, raise ram to 175.. How long do i have to run prime afterwards? 5 hours after each 5 mhz raise is cumbersome :D and btw, do ram...
followed your advice. Ran it for 5 hours or so with no problems to report. Do we go anywhere from here?
i have no problem running it for 6 hours, but that won't make my cpu go any faster :hehe:
doesn't help. I tried 1.60 and 1.65 for voltage too, but still same crash pattern. edit: btw, is it of any use to me that i run it multiplier...
dropped to 12 and voltage back to 1.65 benchmarks ran fine, prime95 ran fine for half an hour, then i stopped it. could it be that i had...
oki, memtest results show no errors after 16 test. So i guess it cpu related? i'd think of upping the voltage, but from what i read 2500 runs @...
166/12.5/1.70 Will run memtest once i leave, i'll update in 4 hours.
Here's the thing guys... both 3dmark03 and 05 crash before the tests are done. 03 crashes on the third graphics test, while 05 crashes on the...
amazing guide. Probly the most detailed and accurate guide i've seen to date. No wonder this community is blooming :hehe: :hehe: btw, first...
Highland3r, i changed CPU Vcore to 1.700, and i booted in fine. Hope it was what you meant. now, memtest86 is a ram utility, isnt it? is CPU...
lets see. I got it mid july 2003. 7*4 = 28. so unless they got me a processor from the future (which is cool), this must be prior to that 39...
Hey, First of all, thanks for your help, its much appriciated. As for system spec, i didn't realize i forgot to mention it - mobo: Asus...
Hey guys, as you can tell i'm new to the overclocking hobby.. thing.. After reading a gazillion posts on how easy it is to overclock athlon xp...
