Another update, first the mid plate just black painted: [IMG] [IMG] Then with the black acrylic and others: [IMG] [IMG]...
thanks for the coment! The pic that you've linked its in SERIES, and I wanna try to mount in paralel like this: (PIC from MALIK) [IMG] The...
Well some other pics of new black bitspower fittings: CPU WATERBLOCK: [IMG] [IMG] GPU (1) WATERBLOCK: [IMG] [IMG] [IMG]...
THANKS!!!! Now a little update with only 2 pics, but bouth I think are imoportant! 1st: Black Plexy top for the Asus 8800GTS physics...
Let's see the continuation of the building: 3x120 rad complete Completed the rad, waiting to be mounted at the top of the case. It...
Another update! this time a little bit important than others :D Let's see the beginning of the building: 4x120 Radiator in the TJ07 First of...
Omg You can see Neptune V2 at #1, and you'll see that i've been using feser blue for 2 years and don't make any problem to my watercooling...
tHANKS! Traxtore give me a part of the mod, like fans, some wc stuff and the vga.
Hi another time, have been past a lot of time with no updates, so, here is: The pics I think that are a little bit better than the old ones,...
How I shoud do the white balance? :S
First of all, I’ve purchased a tripod and changed my camera, let’s see which ones: The camera: Canon Powershot S45 [IMG] The tripod: Vivitar...
Thank you very much! ;)
I'm using Panasonic Lumix DMC-TZ3. Tomorrow will have a good tripod;) I'll show you. The camera is: [IMG] Do you know how I have to do...
Thanks! My pics are awfull, can someone give me some trick to do better pics? :(
The work comes anothertime to the begin;) http://forums.bit-tech.net/showthread.php?t=180486
MAIN GPU: Zotac GTX275 & EK-FC275: This Zotac GTX275 will be cooled by EK-FC275 Plexi-Cooper. It already have a black PCB, so I won’t put...
4x120 Radiator with support: This 4x120 Radiator will be placed at bottom of the Tj07 longitudinally at left. It will have: 4 Ac.Ryan Blue UV...
[IMG] After my last Project (Neptune V2) I started a new project, some parts are recycled but I think it’s not an update from the V2. So, V3...
thanks! your mod is also nice;) the fan's and the grills are very beautiful and you turn that ugli case in a very well loking system right now;)...
I'll have to change bouth in some time i think. because i cont wanna use coils, i think its the worse think that you can put in your mod:S...
