does teh thermaltake aquarius 2 radiator use a 120mm fan? do i need to buy one of does it coem with one? are the barbs 1/2inch? whre can i buy...
what is a good readiaor or heater core that can fit inside a shuttle with 2 120mm fans? (1 fan will be mouned on the back)
i have. ive seen ones with rads all over ones with them inside but normly the ones on the inside are in setups with tubing smaller than 1/2 inch....
i did research and i could not find an answer to my question of what a good one is and wether it can fit inside a shuttle. and i will continue to...
what is a good 120mm radiator that i could (if possible) fit on the inside of my shuttle, or mount on the back.
is it bad if mine runs at 60c ?
the rad can be mounted on the back if nesicary but i need to know a good 120mm rad.
will this pump fit under the rackmount? http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=138&HS=1 also what is a good tiny...
http://bestpcmods.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=BPM&Product_Code=SL&Category_Code=GB
hey i like the anime chicks
zapwizard you would not mind if i used your idea for the custom connectors and leds in the optical drive on my own shuttle would you?
im thinkigng ill just try water cooling my SN85G4 first. i see on lots of threads people put a :search: but i cannot find how i search? could...
why is that? i do not check every part of the forums. i would assume not everyone did. this is the forum for water cooling, which it would seem...
thank you
i am going to be making a water cooled shuttle it will also be hevely modded. i am thinkig of using the sk83g, would the sn95g5 or sn85g4 be a...
I have seen in zapwizards mods he changes all of the plugs to 7pin or other such plugs rather than the normal ones. I was curiouse as to why to...
