Motherboard is Gigabyte EX58-UDR3, can't remember the rest of the system offhand. PC was running windows backup, and about 12 hours in (having...
Mine's inside the front panel of a Silverstone TJ-06. Turn the key, open the door and hoover it out every time I do the rest of the house :D
Having talked to a bunch of airline pilots at the time, they were unanimous that no matter what the air traffic control are telling you, you...
Ceres power do something similar - a couple of kW electrical and enough heat for a house, and they've got a contract with British Gas to start...
So what? They've been comprehensively updated since the Falklands, while the Argentines are still using the very same aircraft. The best they...
I know the feeling. My Dad had a major crash and was in hospital for about 3 months and on crutches for another 3 while I was learning - the knock...
Uh... Venezuela is over 5,000 nautical miles from the Falklands - the UK is over 1,000 NM closer to Venezuela than the Falklands. The distances...
Was anyone injured in the accident? If so then it becomes a legal requirement to report it to the police, at which point the only thing left to do...
Umm... has anybody actually taken a look at the state of the Argentine armed forces right now? What they have right now is essentially the same...
All employers are like that at some points, and if you don't like it your options are to withdraw your labour temporarily (i.e. go on strike) or...
I did Engineering at Cambridge (Peterhouse), finished about 5 years ago now. One thing I've really noticed in the time since I left is that I know...
About the only things not watercooled inside this case are going to be the HDDs, MOSFETs and chipsets. It can't be beyond the wit of man to duct...
Yes, but that's down to the fact that you're using a longer length of tube.
Except the head at the pump is the pressure differential across the whole loop. The absolute pressure at the radiator will be lower if it's a long...
Couple of ideas.... 1) If you can, put the radiator the other way up - right now you're going to get air bubbles stuck in the top, and while...
If you've got a res on it then you probably need to bolt it down, for which you would have to make the holes yourself. Can you do a sort of MS...
Ummm.... theoretically it's possible to put the reservoir anywhere (a siphon after all has liquid above the starting level). In practice however...
Tubes cracking????? Wierd, I've never heard of that or seen any evidence they might. Were they using cheap PVC tubing or something? I've used...
If you're worried about security of tubing on barbs, then get undersized tubing (e.g. 1/2" barbs, 7/16" tubing). Something of a pain to get on and...
Burnout - The position of the radiator won't make any difference in a closed loop - the water is flowing down just as much as it is up. What it...
