Hello. I have got a dual monitor setup and was wondering if anyone knows anything about any software or drivers that enables the use of 2 mice,...
Hello. I have a spare gfx lying aroung and i have seen a PCI to AGP adapter somewhere in the USA. are there any other ways of hooking up another...
Hi i have just got a 9600XT by sapphire and want to o/c it. which cooler do you reccomend me buy for it? thx
Hi. Are there any benchmarks that can test speeds of HDD etc? to see how well mine performs and if i need a new one etc. Thx edit : tried...
Hi all i do AS level electronics at the mo and i need to start an electronics project this january. does anyone have any ideas that could be good?...
Hi i just bought a radeon gfx and when i installed the latest drivers (6.14.10.6404) thats the cat 3.10's i was expecting to find that there was a...
Hi all. I recently purchased some round floppy cables for my pc. before i installed them i was using anormal flat one, with the end connector, not...
Hi. I have found a stable setup and would like to try and adjust the ram timings. i have searched the forum a bit and have found thats its done in...
Hi. Quick q - i will be overclocking my setup and would like to know if i should put heatsinks of some sort onto my RAM. If this is needed, could...
Hi. could someone tell me which is the better card for gaming out of Sapphire ATI Radeon 9800SE 128MB (£140) and the Sapphire ATI Radeon 9600XT...
Hi. i have currently got 512mb of RAM and i was wonfdering if it is worth buying another 512 stick. i would be getting ddr400 pc 3200. this is...
Hi,.im not sure if this is the correct place but it is 100% to do with electronics so i dont think i can go far wrong ^^. anyway i was mainly...
Hi all. iv had an idea that you know those small numpads you can buy individually, is it possible to make a program that could mean that when i...
Hi all i have found a cool java game on the net called necrocave. it can be found at www.sfcave.com . once at the site, click on necrocave and...
Hi all. i am going to get the ntl 600kb package soon but i have 2 computers. i want to use both on the 600k package but my friend told me i might...
Hi, i have got a java prompt box in which i have to enter a password in, to access another part of my site. The only problem is that when i...
Hi, on my website i have got the password thing for a certain link, but when the password is typed in, you can see what is being typed. Can...
hi, i have come across a weird website that is quite interesting. the link is Link removed due to virii plastered all over the site, please...
Hi everyone, i have got a website with no graphic/banner at the top of it. I am totally inexperienced with graphics so i would like some help....
Hi everyone. At the mo, i am unable to play games on my computer. I have got maxtor 7200 rpm HD, pc2700 ddr 512 RAM (a bit poor), AMD XP2500 proc,...
