I have 2 x 200mm BitFenix Spectre Fans, I dont have it hooked up to any kind of speed control and i'm not even sure if it can be hooked upto one,...
Thanks for the response, all the Sata ports are set to IDE in the bios, I didnt change any bios settings before these issues arose, do you think...
Hi Guys, I have an Asus Sabertooth motherboard that I recently purchased, I set it up and installed windows and all was working great, then...
Hi Guys, I intend to build a high spec PC over a period of time, I have bought: Asus Sabertooth X58 Motherboard 6G 3 x 2G Corsair...
I thought the 950 would be an upgrade to 940, but it is like half the price of its poorer performing sibling? Why is it so much cheaper?? Just...
Hi Guys, I am waiting for some money to come through and when it does I will be investing in a new rig. I have narrowed some of the...
Thanks for the responses guys, can someone please explain why I should go for these specs, I can just go to scan.co.uk and find the most expensive...
@thelaw while there is a prefix for custom builds, I would imagine the people new to hardware use it more than the others, so many people might...
Hi Guys, I am sure the most common topic from noobs on here is which one should I get, but your advice would be greatly appreciated. I am...
Thanks for the responses, did a bit of research and turns out they (This particular seller fingers66) might not be legit, VAT is not an issue I...
Hi Guys, I am hoping to procure the bits to build my own PC over the coming months. I am looking at an ASUS Rampage III Extreme Mobo, with a...
