So I'm pondering the pros and cons of getting an Nvidia shield versus upgrading my second pc which i use in my lounge for casual gaming (q6600...
I dont know if this thread is still alive and kicking or not, but am I right in saying that as well as streaming pc games from your pc to the...
well, i seem to have solved the problem though in a rather crap way. Big_malc, apologies but i rudely didnt fully read your earlier post directing...
Thanks for the help guys. I did try and do it via disk management but it didnt seem to work. I am trying the disk part thing Cleggmeister...
OK so i have possibly been a numpty when trying to install a new hard drive on a netgear ready nas v2 box. Effectively I formatted the drive...
http://www.bit-tech.net/hardware/2012/05/10/nvidia-geforce-gtx-670-2gb-review/1 assume youve seen this!? Edit: OOps, i dont know why but i...
I'd wait if i had your rig. IB isnt a huge upgrade from what you have. Not so sure re GPU. Is it much of an upgrade from your xfire set up?
Could be worth considering dropping down to a 3570k to save pennies if you are considering 670 sli. It OC's as well as the 3770k so in some...
560ti probably still holding its own but a gpu upgrade may be nice :) 8/10 To add to my specs in my sig, i have a Dell 2408wfp (1900 x 1200),...
Just completed a new build based around 3570k and 680gtx. Very happy with it! Ive kept my old pc with a q6700 and 5870 as a gaming rig for my...
I just finished a 3570k new build today. Havent OC'd at all yet but gosh its a nice step up from my old q6700 - I use mainly for gaming and...
Cheers for the advice. Will have a gander at some reviews of it.
Thanks - I've added said ram to my list! Out of interest, i put thermal paste down but realised most coolers will come with some. Is the stuff...
OK - having sought some advice for individual components here is my new build. I am planning on driving to scan to get the kit tomorrow so any...
Thanks for the help guys. I'm not too hot on different size mobo's. I am planning on getting the case below, so theres plenty of space i imagine....
Can anyone reccomend a decent mobo for an ivy bridge build. Budget around £150. Will be in a gaming rig so would like to overclock (nothing crazy)...
So the 2550k is basically a slightly higher clocked 2500k and isnt ivy bridge? (if so, I appear to have made a schoolboy error!!)
About to invest in a new build and was going to plump for a 3570k, but have heard of the 2550k as being the same difference but with no gpu and...
I think whats at the heart of this is deleting stuff that deep down i know i'll never use, yet somehow the logic of 'I can just buy more storage...
Just a general question really. I currently have about 1.75tb storage (spread over 3 Hd's) with about 400gb free. I have loads of games and movies...
