full size
thanks for the advice. the psu gets here on Wednesday. Hope this fixes it and the crap psu hasn't done any damage... Metal Gear Solid V in 4k...
https://youtu.be/YFNnMI1ZZkQ Video: https://youtu.be/YFNnMI1ZZkQ Ok i will buy the psu Please see above video for the fault. This continued...
can you guys recommend a psu? if it is working ok, I just risking the adapter melting right...??
Plugged everything in last night and it is all working! Glad I got that adapter though. The supplied adapter converts two 6 pins to one 8 pin. I...
just bought this: https://www.amazon.co.uk/Startech-Express-Video-Power-Adapter/dp/B006PHXLRG/ref=cm_cr_arp_d_product_top?ie=UTF8 will it work?
Hi All I just ordered the Palit GameRock NVIDIA GeForce GTX 1080:...
Hi I am running an 8800gtx. When I look at the hardware monitor in RivaTuner, it tells me the core clock is 576 MHz. I thought the gtx ran at...
Yes - it reboots constantly in a cycle. There is no HD attached. I will try to find a PSU.
It does the same thing when the GPU is not plugged in. surely without the GPU there is enough power? I have taken the mainboard out and refitted...
The CPU fan connector is only 3 pin, not 4 pin. does this matter? all 3 connections have been made to the motherboard power sockets. reseting...
Please help! My system won't boot. I just finished building it. I hit the power button and it switches on for about three seconds then reboots....
Thanks for the help! I was too dumb to do a price sorted search for a 8800 GTX at overclockers it seems :| I have bought the Bliss. Is there...
Thanks but thats the one I saw: £8.25 + £187.99 Any others?
Hi all, I was planning buying the GTX for about £185 from overclockers.co.uk but now they have put the price up to £197.68 !!! Does anyone...
Crap! I just bought the 8800gts for £180: http://www.ebuyer.com/product/138551 Should I cancel the order?
Hi I am planning to overclock an E8400 on a IP35-E. Will I need a NB heat sink e.g. thermalright HR-05 or Zalman:...
Hi all Before you delete this thread, Scan does not have this item in stock! Does anyone know where to buy an E8400 for around £130? The...
£37.01 inc VAT here: http://www.thecoolingshop.com/product_info.php?products_id=2696 That was the net price, £31. I have just bought the...
I can't remember the exact wattage of the PSU. I bought it a while ago and it is waiting for me in another country. You're right though - why...
