May sound a bit more.. Adventurous than storage solutions you've already conjured up. But, simply for the price a single Samsung F3 1TB drive can...
As mentioned previously, if efficiency is something you care about, stick with the GTS 250. To further this argument, I'd also suggest sticking...
That's unfortunate, contact the store you bought it from and ask if they will replace it. Current ISO standards dictate that a new product with a...
Sure you connected the front panel USB lead to the headers correctly? Should have worked. That sounds more like it, I thought 'Booting from...
Sounds like it's trying to boot from a device the motherboard has deemed as a primary boot drive (Likely a HDD), and since there's nothing on it,...
What beep sequences is it giving, if any? Or is it a single beep? Also, that's standard, the PCI-E slot will still be providing power, and the...
Make sure the card is inserted into the PCI-E slot fully, and make sure any power cords (4pin/6pin/8pin PCI-E and so on) are connected to the...
629 Just bought a GTX 460 (Asus 768MB Top) to add along to my aging 8800GTS 512. May buy another in a few weeks.
Ouch, that's some bad luck, did you return it to Ebuyer? I'm quite surprised I've always had such an amazing experience using them.. I'm also...
Its possible to tighten them too far to a point where something snaps.. Usually a thread on a screw will do that before anything else though....
Such a shame, I really enjoyed the BETA, the game was actually quite fun... Guess it just didn't appeal to many.. I blame MTV.
If you have a screw driver.. You won't need anything else.. Perhaps a beverage. Although if you want to engage in some decent cable...
Whilst it is an option, I'd advise against downgrading the HDD simply due to the price per gigabyte a HDD of that size offers. 500GB drives for...
Originally.. Yes. Damn Sky and thier terrible service, only sites I had access to for the past 2 hours were Ebuyer and Bit-Tech, so I couldn't...
I'd recommend the following build. A cheap but brilliant quad core, coupled with a moderately decent board, and a brilliantly priced 4GB kit. It's...
EVGAs Hydro Copper version is probably the best.. But that costs a fortune. That Asus variant would be fine, but I suggest you pick this up...
EaW and the expansion are both great titles, especially at that price. To make it even better, there's a tonne of mods for the game.
You pretty much picked the best GTX 460 available, when everything is factored in. It's the best overclocker (after the MSI Hawk, which is...
http://www.dabs.com/products/asus-geforce-gtx-470-1280mb-pci-express-hdmi--fermi--6NVP.html Cheaper than OCUK. As for the cards themselves,...
3.1GHz on my Q6600 B3.. Would be 3.2 but my other board recently died.. Mind you, surprised this old P5N-E SLI pulled that off! .. Also,...
