Well…I don’t really see what the big deal is on battery life. I mean any road warrior knows that you have power receptacles all over the place in...
A good compounding is always required for lacquer paint jobs if you want a high luster finish. It’s how you go about it that determines the...
Nice job on the weathered look…the icon is really cool all lit up and stuff. :thumb:
This is true...but he stated that he intended to use compound to remove bumps in the paint. That is not what compound is made for...hence the...
Lacquer is a type of paint...so reading you last post, I think you may be a little confused. What do you mean by "on the paint itself"? Are you...
Be careful about the compound stuff…there is a lot to consider when using compound. First of all DO NOT compound enamel paint unless it is at...
Correct...Sand any meatal areas with 220grit paper and then 3 coats of pimer. Let it dry then wet sand flat with 400grit wet/dry paper. Rust paint...
The secret to painting plastic is to use as little as possible. The lacquer thinners in the paint will eat into the plastic and bond.
Your already getting the modem so just get a 4/6 port router/switch. It is real simple to setup through your browser. Type in the ip logon and...
You don’t need all those fancy paint to paint your bezel. Clean is with a prep- sol type cleaner, scratch every inch of the plastic with a worn...
Painting a radiator is putting a blanket on it...
Great site...took a long time to stop laughing. And Hwulex's reply was even better.
If you go to the Glen, you have to do the gorge. It’s pretty awesome.
Hwulex…This doesn’t sound like kids. Just because they took the gaming stuff does not mean they were kids. Just the opposite IMO…First they...
Try this..."crucifixion wrist"
Were ya going? Back to Canada?
Watched it last night…another good flick. Denzel did another great job…as always. The movie had me going right up to the end. If you’re into...
Christianity remains a faith based system because no one has been able to prove/disprove the resurrection or even that he existed…but if by some...
You can start by right clicking on the email and go to properties. This will give you the info in the email header. Happy hunting… :D
Didn't I say that awhile back? :confused:
