I’m working on building custom tags for php, so far all has been going well. I have made a set and a get tag. input <rmpw:set...
I want to transform an xml doc All I need to do is change all the elements names from a short description to a long one so <VERS/> would...
I'm trying to create a *.mdf database without haven to rely on a the SqlConnection Class currently I execute a sql query to make the database but...
I have a small bit of php code that is designed to include multiple files however it will only include the first file then is seams to break out...
sound like you want something like CVS but does not keep multiple versions did a search and found this http://www.siber.com/cvs-via-ftp/ which...
what I did was to setup apache and the php module then you can dump all you files into /var/www then view them through firefox at http://127.0.0.1
I just read this article on C++ castings http://www.informit.com/articles/article.asp?p=397657&rl=1 I normally use C# and Java which this...
I had a very similar experiences with my 9700 pro when I moved over to a new motherboards, I tracked it down to the DD GPU block the weight of the...
well it is going at 10KB a second I'm thinking this could be a problem with mono at this speed anyway here are my two files GEDCOM_5_5.xsl...
is there any way of speeding the transformation process up as its painfully slow on a 500KB file
thanks that's graet It will do the job perfectly :D
I have an xml document <INDI>@I14@ <NAME>Charlie Accented /ANSEL/</NAME> <SEX>M</SEX> <BIRT> <DATE>15 JUN 1900</DATE> </BIRT>...
have a look at the gtkmm web site under documentation remember gtk is C not C++ and documentashion is not that good so with c++ its going to be...
I gave DarkBASIC a go when it first came out and you could make it do something like this and there are probably a lot of samples doing most of...
well my sample data does not appear to be 100% valid as the last line is not a multiple of 4. :miffed:
well I was just referring to the 6-bits into 8-bits but here's what I got so far private string[] DecodeImage(Node inBlob) { if (inBlob...
I done it :)
ok trying to do this in C# I have converted from the characters into the binary representation stored in a byte however I can't concatenate it...
ok that makes a lot more sense is this just a uuEncode and uuDecode then ?
well I got some data encoded using the method explained here http://homepages.rootsweb.com/~pmcbride/gedcom/55gcappe.htm just it don't make much...
