Nah wouldn't pull alot.. its only a few l.e.d's.. Think things like webcams, cordless mouse receiver thingy's would probably take more.. If it...
Wait now i'm confused... How the gone off biscuit barrel does plexi cases work then? If grounding is so dam important
Just a quick question, do you intend on keeping that q-tec psu? i had one for a while then i changed to my rather sexy enermax.. what can i say!...
Man that looks SOOO NICE!!! I'm very envyous .... Rock on dude, keep up the hard work, and often :D
Sorry if this sounds a little stupid, but heat travels up so surly the HD's and psu etc would be best at the top? I really don't have a clue do...
Drill? :confused:
Tell me if this is a little stupid, but what happens if you have a sub and amp etc? all high powered stuff that was previously running through a...
Well ive got a PIMP'in idea.. That lovely nissan sign... i spy a vandal resistant switch to go there for power :D That way you keep in with...
Keeping with the industrial look, why not have a old bullet case from the army and put that on the side, and hold your res in that? You know...
Confusion! Err, sorry if this sounds stupidly dumb, music playing on continuous? How you sposed to change song if you don't like it? What if you...
That is some SUPER slick stuff! Sorry if ive missed this somewhere else, but what are you using to glue the plastic together? Don't kill me, i...
Great stuff, at first i was a little confused on what was going on (blonde moment :wallbash: ) but then i got the drift and what can i say.. SCHWEET!
Although it would be a pain in the bum, it peeled because it didn't stick.. ok that sounded stupid.. :wallbash: Anyway, take back the paint...
Which is water cooled if you look.. So no need for a fan there! Probs no need for one on the rad either :rock:
Basically ive got my system set up really tasty at the moment bar a few things. Now im running a Audgy soundcard, gone into settings changed it...
hi eminem.. slim.. shady.. anyway.. ive done the same i used 12V Doorbell wire. In B&Q you can get 25 metres of it for £3.50 ive extended...
Ok, Ive not read all through this thread but i would like to post a idea. So that you can keep it on all the time, add some caps, enough to...
Take this opertunity to purchase a nice new hard drive :hehe:
Ok, sorry about the dumb questions comming here. Them screens, do they have everything with them? like are they them ones that can show you...
I manages to bend two of mine, and they went PING! Bugar :duh: But thinking about it, the rods will come in handy for something :rock:...
