I did a google but wasn't sure if I could use any ICH10R drivers, or if I needed a specific Gigabyte one. I'm not too hot on motherboard...
I've bought a new Gigabyte EP45 UD3 motherboard after my old pc broke. I'm currently using a Puppy Linux bootable cd for web access but am having...
Ha ha, you know your stuff Austin :) I was just making a joke about my slow pace of upgrading, but for what I use my pc for an average...
I got XP pro, so much better than '98 :lol: I was hoping to wait until Vista cam out and lepfrog a whole OS release, but gremlins got to my aged...
My 2c Anelysium, why not give overclocking a go first with your current rig. I'm using a budget Asrock motherboard with standard bios $70, OCZ...
I thought I was doing well to get 2.5 out of my 3200 (std 10 x 200). Also remember that your motherboard, cooling, PSU and memory will all play...
Good film, gets my vote. Nice to see a well made, well shot film that requires some brainpower to enjoy. Wish there were more like it :lol:
Thanks Austin, I'll try out that player. I ended up doing another fresh install and the problem sorted itself out :D I guess that was why none...
Downclocked memory to 2T as 1T can give odd problems with this motherboard. Ran Memtest with no problems. Loaded Atapi drivers again Loaded a...
I'll upgrade to XP pro when I've got the money, already tried another pioneer dvd reader. It will read programme DVDs and CDs it only seems to...
Can anyone give me some advice on a wierd dvd reading problem. Specs: Asrock Dual sata 2 AMD64 3200 OCZ Memory 512MB NEC ND 3540 DVD drive...
Thanks all, I did find a completely anonymous service, but it was much more than I needed, I just wanted to avoid junk mail and calls to my...
I'd like to set up a new domain to point to another website, but don't want my details all over the whois requests. I'd also like to set it up...
Cartoon No 4 Changing the mouseover start has helped :thumb: However I am using 800x600 to view my browser, and if the start link is in the...
A bit of googling helped me out, I need to be on level ground for it to work.:)
Just a quick one, how do you deploy the forward base? I can drive it but when I jump out it just stands around. Can't find the answer in the...
Excellent work bard :thumb: So much more satisfying than just buying a pre-mod case :rock:
If your psu fan only has two wires it is likely that these are just +ve and -ve, you would need a third wire for the monitoring. The black wire...
The 8500 competes with the older GF3 Ti 200 or similar, I'm not sure what Dx rating it had either. Here is a comparison chart from Tom's H...
Nice sleeving, much neater. Will you do something with the mobo cable? Some metal polish would bring up a nice shine on the unit.
