Just to remind you.. the project isn´t dead.. I´m just currently in a money problem which stops me from moving on.. Because of spce problems,...
Those chrom profiles look really sweet when mounted.. I have a stacker too and I was thinking about polishing the profiles, but i were in doubt...
#105 hehe.. you´ve got to remember that it´s carpaint.. it can take pretty much.. kind regards Thizen
#102 .. yep.. I think you´re right.. #103 Well, it´s just a test assembly.. I still need to paint the inside of the parts.. And I will have to...
Case pictures Hey! Took som new pictures of the paintjob today :) It´s really shiney, actually I have never seen a car as shiney as my case...
#100 Thank you :) Not much i happening at the moment. The case was painted today, so I can pick it uo at the paint-guy tomorrow .. Looking...
#97 Thanks.. #98 The case is of for paint now.. I am still waiting.. But I am also looking forward to see them mounted :) kind regards Thizen
Little update Hey modders.. Today i polished the front door (aluminium) and I finished the electronics box for the inside. [IMG] [IMG]...
#94 thanks... I used the Lathe and the cnc router to make the cross in the middle and the 4 M4 holes for the bolts.. the plexitop is handmade.....
oh, damn.. sorry for that much misunderstanding .. hehe.. well they are even more watertight.. they are like 2000% watertigh, you wouldn´t believe...
oh the top fittings.. well as there´s no water in the top area and the fittings will point upwards, there will be no water in contact with them....
#88 I know what you mean, I have tried it many times, where others have used my ideas or "the ideas I also though of" .. The waterblock itself...
Waterblock update Hey.. a little update on the waterblock.. I made a plexi top for it, so that I might use it on min cpu (socket 754) .. I am...
#85 Thanks for the link, the case looks very nice in mirror black, just got the news from a local painter, he can paint my parts in gloss black...
#83.. the whole front door will be polished, if that is what i choose to do.. And then the flat front will be black just like the rest of the...
#81 .. well all the perspex is going to be painted gloss black (really shiney!) So will the front, but I´m tinking about polishing the front door,...
Well, If you want to change the anodized color.. Most places where they can anodize, they can remove the anodizing too.. I was offered to remove...
#74 you´ve got that right :) #75 Thanks :) I agree #76 Thanks.. I will :) Kind regards Thizen
#72.. yea, well actually the most shiney part is the ends.. and that´s stainless steel.. it´s way easier to polish.. but If i had made it all from...
Extreme eye candy Hello again.. got some real nice for you this time.. finished the reservoirs :) I was speechless when I was done assembling...
